I was looking at the price of tooling gel coat and tooling PER; epoxy doesn’t cost but a dollar more sort to speak for the same amount by volume.
My epoxy costs $35 for 1.5 quarts when mixed
My tooling gel costs $35 for 1 quart.
Tooling PER cost is $20 for 1 quart.
I guess cost isn’t such a big factor in this because i hope to pull many parts with this mold, so quality is key. The mold needs to maintain the plug shape/size exactly or very very close to. Would epoxy create a nice smooth mold surface? Or is it best to lay down a coat of tooling gel coat then once that B-stages or just after B stage switch over to the epoxy? It is a 4 piece mold with many countours. I’ve thought this out in my head for a couple hours and 4 pieces it has to be. How thick should i build the mold? It will be braced with gussets all the way around… about 25 of them. I’d take a picture of this thing, but without showing you 8 different angles picture would be useless.
As for the part, I have decided to use f/g cloth sandwiched between two nice outside layers of 2x2 twill carbon fiber. Money’s running short and this fender is a freebee almost to the customer who is trading me a couple other oem parts for a c/f fender. I am thinking of 3 layers of 3 oz satin cloth for the meat. Vacuum bag procedure after wet lay up.
On another topic/note: does kevlar lay down nice and bond well to c/f cloth? Is it possible to do a sandwich of C/F:kevlar:fiberglass cloth:C/F and have it all bond together nicely? Or is that just looking for a disastrous result?
