Ok, so hopefully some experts can jump in here and give advise.
I have been having trouble getting a perfect vacuum on my molds. I have made 4 molds so far and I can only pull a perfect vacuum on 1 of them. I was starting to think that maybe I am building the molds incorrectly and they are not “tight”.
I have attached some pictures of my molds. The process I use is to lay the part up with clay so the part extends down to a flat surface, and then I brush on an epoxy gel coat. After that I lay fiberglass on the back side for strength. I do this in a pre made box as shown in the picturess.
Since none of the pieces I am making molds from will lay flat I have to build them up with clay, you can see in the pictures that the clay leaves rough edge. It is nice because you can see the part outline.
In the pictures the mold that I get a perfect vacuum on each time is the smooth one.
So here are my questions:
Is how I am making the molds correct? How can I ensure they are tight?
Since these parts need so much clay should I just use a thin wood to make flanges?
Any additional advise?
