I have a question. I noticed epoxy (when compared to polyester resin) tends to gas off slow. Meaning air bubbles take longer to rise and “pop”.
Do you pro carbon workers think it is possible to use epoxy in a two part pressure mold? there would be no vacuum just clamps holding the mold halves together. Would this trap visible gas/air bubbles in the part surfaces? The laminate is 3 to 6 layers of carbon fiber.
note: I probably would not use clear gel coat unless it became necessary.
Q: Will polyester resin odor supressors tint the color of the resin to such a degree that it would be visible on a carbon fiber/clear gel coat part?
Thanks for the help!
