With vac infusion, is there a way to speed up the cure process? Since work time is relativly short (just suck n’ go from what it seems) something with a lower cure time would be ideal over a longer hardener yes? No working it by hand, so your window of work should be less than 10 minutes once the resin is mixed…
Also, for the first time I’ve got a part that the epoxy resin didn’t cure. It’s been 2 days, and it’s still tacky. My guess is that the ambient temperature fell below the 72degree (whats on the can anyway) threshold. I’m sure the mixture was right, is there anything I can try to salvage the part? It’s been below the 70deg mark outside the last week, so I need to look at my options.
Thanks!
James
