Epoxy Compound
I just got a quart sample in. cant wait to use it! =)
I know for sure i might not continue using it after the test, as its a big expensive. BUT the weight saving, and it MIGHT be a bit more money and time saving. its 270? for a 5 gal pail, its a 1 / 1 mix ratio. and 1 pail covers 300? sq. i gotta look up the # 1 more time to make sure. but if you think about it, its a good amount of compound. this is considered laid on 3/8th of an inch which is enough. then u put some fiberglass to back it up.
huh?..
I have used epoxy compound before, i didnt like it. it would be good on very small parts, but anything medium or big you would be better off with FRP
