Hey,
Need some opinions, we are trying to reduce our finish time on CF parts we produce, everything we do is epoxy based, when we produce our parts (either VARTM or RTM) we always spend a crap-load of time finishing them off, meaning clear-coat applications. We often get some pin-holes in the parts which we repair prior to clearing but even when pin-holes are not present it just feels like everyting needs 3 hits of clear and 3 blocks in-between which is just getting tiring.
We have tried hitting the moulds with clear-coat and then laying up after they tacked up, better results but still needs to much finish time, did the same with Duratec also, better again, but like the clear in the mould, needed far to much time finishing the part to high gloss.
How do you guys deal with this who also shoot in epoxy? Is there a gel-coat that is epoxy based which will seal the surface in so we just need to process 1 maybe 2 coats of clear to finish the part off?
Recommendations? We are really happy with the resin system we use, no leaks in the bags, we often bag the whole mould to ensure no leaks from the moulds either, there is got to be some product or process that can yield a part which can go for a single hit of clear, no?
Also, what are you guys using to prep the parts for the clear? We usually give it a quick acetone bath and wash down with a desgreaser, then wash again prior to clear.
Opinions please?
