I will be making Carbon Fibre fuel tanks shortly and have a couple of questions.
Which Epoxy’s are resistant to petrol? Are there addatives available to non- resistant epoxys?
What can I use as a Gel Coat as polyester Gel Coat is not compatable with Epoxy. Can I use Epoxy mixed with Silica to make a compatable Gel Coat that I can spray on to mould and let cure, then lay my Epoxy? I could also do with it being UV resistant.
I need some sort of a Gel Coat type skin sprayed on first so that when I demould I am able to have a layer that I can sand and buff the flange lines out as the mould is a 4 piece and there will undoubtedly be join lines.
Thanks:rolleyes:
I did not meen for my reply to sound bad, somtimes the problem is when you can’t actually talk to someone. Please accept my apologies if I sounded rude.
