I apologize if this post appears twice, there was some weirdness with the forum software.
Anyhow,
I am creating parts with a slight compound curve (think skateboard) with one skin of cf, a core of aramid honeycomb, and a bottom skin of cf. My current work flow is painfully inefficient.
First, I wet layup the top skin on my mold and vacuum bag it over night. Then, I wet layup the bottom skin and bag it over night. Finally I lay the honeycomb between the two skins in the mold and bag that over night. I am really a novice at all this, and am following a procedure recommended to me by an acquaintance who makes CF parts for the medical industry.
This three day process seems terribly inefficient. What I would like to do is wet layup the top skin, lay the honeycomb on that, and lay a wetted bottom skin on that all into the mold together and bag once. I was told that I needed to bag each skin separately to “squeeze the excess epoxy” out first and then laminate them together.
I’m not sure why I need to vacuum squeeze out excess epoxy. If it is a matter of weight saving, it really doesn’t matter if my part is 10 or 20 grams heavier (over a surface area of about 350sq.in). If it is a strength issue, then yes I’m right at the failure threshold so I can’t weaken the design much further.
If doing it all at once is OK, what is the proper procedure? Presentation skin directly on the mold, or should I put peel ply between the top skin and mold? Peel ply on the bottom of the sandwich? No peel ply?
If I really do need to do each skin individually, and then laminate, is there a more efficient way to do it? I have only one vacuum pump, one mold, and one bag. I can make more molds and buy another bag, but I can’t really afford to buy another vacuum pump. This is for a hobby/hobby business. Not really a commercial endeavor.
Suggestions?
