I have a Edwards GVSP30 220V pump for sale. The pump has pumped for 4912,9 hour, this is as new for this kind off pump (I have the same with more than 18000 hour and still runs great). Pump pulls the specifications given below:
Displacement: 30 m3/hr-1
Peak pumping speed: 25m3/h-1
Ultimate total vacuum: 1 x 10-2 mbar
Inlet connection: NW40
Outlet connection: NW25
Maximum allowed inlet pressure: 1000 mbar
Maximum allowed outlet pressure: 1150 mbar
Motor power: 0.6kW
Electrical supply: 1 phase, 50Hz, 230V
Enclosure rating: IP44
Leak tightness (static) 10-4 mbar ls-1
Operating temp range: 5 to 40 * C
Weight: 44 kgs"
The price of this beauty is €1500 excl. shipping, this pump is located in Holland. The new price off this pump is around €10.000. Shipping this pump is f*cking expensive because it’s weighs 44 kg.
