Hi guys, My brother and I are using easycomposites uni-mould tooling system and have to say I like the process and how well the surface cleans up after 1500/2000 wet sand and polish. Unfortunately though, we’ve scrapped a very nicely finished door card mould and two small vent surround moulds from poor release as I couldn’t get our wet lay to release at all (used all Easy Composites products: Easylease, polyester gelcoat and polyester laminating resin; 1.5- 2% MEKP, 20degC, 48hr cure) - better joint than some bonds I’ve made in the past!
I did a back-to-back test on a glass panel and saw no difference in release with wax or the Easylease I’d used, however a PRF epoxy released much cleaner than the poly, so I switched to that. We then tried to make some of the smaller vent surrounds in replacement moulds and had the epoxy grab pretty hard as well, to the extent that although both parts could be removed, there a several areas of stress cracks in the tooling gelcoat.
So, my questions are - has anyone else had issues like this with uni-mould or a similar tooling system, and what was the solution? Will post curing the moulds make a significant difference?
I’ve not got loads of composites parts experience, but I’ve done enough to know that i should be able to get under a corner and then pop the whole thing without much effort… I hope you guys can help, we’ve been working on this for almost a year and all I have to show is a lonely wife and 5 busted moulds!
Thanks, Jonty
