If anyone is looking for a good low cost / high quality epoxy based tooling / surface coat product, this E-Z Lam black surface coat from ACP Composites gets my double thumbs-up.
I haven’t found any other epoxy gel coat-type product that is even close to being comparable to this one. I have tried som truely awful epoxy gel coats lately. Max GPE white gel coat was the worst one ever btw…
The texture of E-Z Lam is perfect. It spreads easily, clings to vertical surfaces, never fish-eyes, sticks to you cf, fiberglass or epoxy putty mold-making materials. It releases easily from both plug and cf parts. It cures at room temp but can withstand up to 350 degrees, so you have the flexibility to use it for wet lay-ups or heat cure pre-pregs (if the rest of you tool holds up).
Unlike most other epoxy based products I have used, this one polishes easily to a mirror finish (with the right product and buffing gear) after imperfections are sanded out. It sands easily enough too but holds a polish for a long time.
It comes in large gallon containers, or quarts size tins for as low as $35 and a quart of this stuff goes a long way. It has lasted for dozens and dozens of molds for me.
If anyone has found a better epoxy based mold surface coat / gel coat product, I would love to hear about it so as can give it a try but for anyone still looking, maybe I can help save you some time with this recommendation.
I don’t know much about ACP Composites except my positive experience with this product but I plan to try more of their resins very soon.
