Hi all,
If anyone out there is using VTF, what are your dwell, ramp and peak temp figures?
I have had good success with a straight forward 12 hour cure at 70C, no ramping:
However, I would like to knock parts out quicker. I have experimented with higher temps and different dwell times, but none have yielded results as the example above (either pinholes or print through happen). I have followed the 2 degrees/minute ramp rate and dwells at 65 as the spec sheet recommends.
Any tips appreciated,
