Dust Collector
Whats a good, not so expensive dust collector? what are the #'s i should be looking for…
harbor frieght or grizzly…as big as you can get.
One trick here is to get a plastic 55 gallon drum, on the removable drum top, insert a fitting with a tube going almost to the bottom and add another fitting that goes to a shop vacuum.
The fitting with the tube goes to the media or dust collection spot, the other fitting goes to the shop vac…
Now fill the drum 1/4 full of water and add a little laundry soap.
Now you have the largest water pipe / Bong …opps :rolleyes:…dust collector that the shop vacuum will never burn out from the dust!
