What do you guys use to thin Duratec? Thanks!
For Duratec Sunshield the data sheets says to use MEK.
That’s what I use. 10%
Thanks Fasta but I’m using a polyester primer.
Can’t get the Duratec Thinner? In all honesty, I suspect the Duratec thinners is exactly the same as any other lacquer thinners.
MEK may work too, sunshield is a polyester too (so they say).
You could also try styrene monomer or just acetone? Do some tests.
Thanks guys. I went to the Duratec website and they recommend MEK solvent. It just didn’t dawn on me to go to the website until I saw some of the responses from you guys:)…lol
