will I be ok ifI mix the high gloss additive with normal primer? My supplier is out and 2 weeks till he gets it in (surfacing primer I mean).
I guess you’re pretty safe if it’s a polyester based primer and not a urathane based primer.
yeah it’s a poly primer
two weeks? I could get you a can in four days, unless of course they deliver mail by donkey in Idaho.
Take a loan out and buy from fiberglast
composite one wants an arm and a leg for it as well.
what about the topcoat, it builds very well and sands well too, maybe I will use that. I got a couple gallons from composites one that are 5 months old for $20 a gallon. So I need to use them
what is the shelf life on that stuff?
try and pigment it black and give me a report on what happens.
I will do that, I remeber hawkeye saying it has a 8 month if I am thinking right, I will try an pigment it
it did not take to the pigment very well, I thought I had to use a lot and it just tinted it not made it a distinct black, then when sprayed it came out a lot clearer then I thought it was going to!
cool, thanks. I would do it myself but my garage is under renovation right now.
are you going to build a booth in your garage, spray booth I mean, I remeber you talking about it. If so I got some booth plans
spray booth and I’m putting in a wood stove.
