dry method vs wet method
alright, this is my first post, hi all…
so… what exactly is “dry method” and “wet method?”
are they both still made from prepregs?
TIA
p.s. carbon werks used to be a sponser for E46fanatics.com right?..
depends which one you are talking about.
Dry carbon = prepreg. Prepreg = carbon that already comes with resin impregnated into the cloth. You just lay it up into the mold, vacuum bag it and cure it under high heat and pressure.
Wet carbon is made by hand. You lay the dry cloth into the mold and brush on the resin and let cure at room temp.
No I didn’t sponsor any forums. Being a forum sponsor is a lose lose situation. Happy customers don’t say anything while pissed off customers make sure the world know about it. I think the company that you’re talking about closed down last year or something.
My thinking of what he was asking was a wet lay up is laid up wet then vacuum bagged.
Dry lay up is VIP (Vacuum Infused Process) where it is laid up and bagged dry, pull a vacuum and suck the resin into the part.
[quote=“cfcrafting”]
depends which one you are talking about.[/quote]
@.@ which one whaaaa???
Evan, thanx for the reply. So… prepreg= only used for dry method?
I fail to understand how ‘wet method’ end up with a smooth glossy surface.
GGROP, I believe VIP = RTM… (resin transfer molding) right?
