i use both on a the cutting machine i operate. Cutting prepreg of course.
It depends on what the backing material is like on the prepregs. Some stick well and give no issue with the drag knife. Some come off easy and so I use the oscillating blade. Both last a long time. The oscillating blades i have are more like tiny little sword shapes, very fine point, for very detailed cutting. I also often cut templates for scribing and trimming.
if i had to choose one, i’d go oscillating for sure. Covers more material types. Less resistance through the material. Try cutting high mod uni with the regular drag blade… bleh.
for longevity, the roller blade is probably better. I don’t use it cause my machine has a conveyor and i’d need to install the plastic shield to use it. There are also powered rotary blades available as well.
