i got this weird thing happen on my last infusion.
first of all, im stupid, i know, i didn’t close off the resin feed, i got carried away cause the resin was infusing real slowly towards the end of the mold and as soon as it reached the end, i set the timer to my vac.pump to run for another 4 hours and left…
2 days later when i tried to demould it, the resin in the most of the product was still sticky, so i thought it must be the cold… so i left it in the mould for like…6 days. tried to demould it then, and it was still soft in most parts. the resin in the container was rock solid since day two too, so i dont know what happened in there. my first thought was that the resin uses a diffrent mix ratio than the usual 2:1, but then the resin in the feed container would be sticky too… anyway when i demoulded it, the product was soft, except some areas near the resin feed, and was also sticky ,and even wet at some points. took a lot of time to clean the mould with acetone…
any ideas?
