I’m looking for some help at getting a cosmetically smooth finish on both sides of a sandwich panel and wonder if infusion is the way to go? Wet layup vacuum bagging is not getting the result I want in one shot.
I am looking to create a double sided flat panel (50" by 20") that is vacuumed on a plexiglass surface (no mold) using epoxy resin. The core is 3/4" 5lb Divinycell H80 because the panel must be able to handle repetitive slamming and impact abuse.
With wet layup vacuum bagging, I have only been able to get a cosmetically smooth surface on the bottom side, which cures against the plexiglass. The top surface is textured due to the peel ply. How do I get a smooth finish on top also?
My wet layup top bottom to top consists of:
plexiglass surface
3 layers glass
Divinycell H80 core
3 layers glass
Peel ply
Breather
Bag
With infusion, I am thinking of getting rid of the peel ply and breather and letting the top layer of glass lay directly under the vacuum bag. Then, use spiral wrap on both ends to draw the resin across the panel length wise. Will this work without flow media and peel ply?
I have done some research on infusion and feel I’ve got the basics of it down. However, I still have a few questions.
Is peel ply and flow media necessary with infusion? I am thinking of laying the bag directly onto the top layer of glass to get a smooth finish. I am going to use a low viscosity epoxy resin.
Can I infuse both the bottom and top sides at the same time without using a perforated core? Will the resin flow evenly on both sides?
With wet layup, I have sealed the core prior to vacuum bagging to prevent the divinycell from drinking up excess resin. Do I need to seal the Divinycell core with infusion? I don’t want to use a perforated core due the impact and slamming abuse the panel will take.
Any help would be appreciated before I begin my testing!
