Alright, I’m trying to understand how double bagging is capable of improving the Vf of infused laminates. I don’t build “bling”. The things that I build are structural so the topic is interesting to me. I’ve been reading about claims of 70% Vf which is hard to believe.
So why does it work? I’m trying to understand the advantage. I’ve recently done some small test panels (2x2) and seen absolutely zero improvement in the Vf.
Facts: The outer bag is unable to exert a force on the laminate by a function of atmospheric pressure. If the inner bag is vented to atmospheric pressure you have 14.7 psi pushing out and 14.7 psi pushing in = a net force of zero. If I apply vacuum only to the outer bag then I just increase the pressure on anything between the two bags but no pressure is exerted to anything inside the inner bag.
If I apply 29.97" Hg to the inner bag and 29.97" Hg to the outer bag is have 14.7 psi pressing on the laminate. When i open the infusion inlet I have 14.7 psi pushing the resin in. The theoretical pressure against the laminate is now zero and the pressure applied to the breather between the two bags is 14.7 psi.
So, is it the friction between the two bags that holds the shape of the bags to hold the pressure against the laminate when the inner bag pressure is reduce during infusion (14.7 psi pushing the resin in)?
