Evan - Great write ups! I have been trying to learn about carbon fiber fabrication for nearly a year now, off and on.
I have even tried - trial/error attempts. After running across this help forum, I’m relieved! I’ve read numerous articles regarding and emailed companies who do fabrication of aftermarket parts as you do, but sometimes I feel that I’m prying into their business when I ask specific questions regarding materials they use.
I’m assuming this is what this thread is about - questions questions questions!
1st project -
This project I have been trying to work with for quite awhile and have had no succcess whatsoever - maybe you can review my basic process and see if you agree, I would highly appreciate it.
Objective: Carbon Fiber Door/Window Pillars …Esentially covering stock (verticle) door/window pillars w/ CF and having a deep / crystal clear / 3d finish.
These pillars are unforunately not flat - they have an arch to them to fit the body lines of the car. Hence - not the ideal surface in my learning. I have attempted many ways to manipulate the drapping of the CF upon the pillar. Unfortunately, it seems that it continues to bubble up / float around the edges of the material.
I have followed essentially what your basic tutorial w/ these parts but w/out success - my biggest concern is that I feel that I’m not using the correct type of resin and preventing bubbling / floating of fabric.
Resin: I’m trying to find a resin that works ideally with CF that gives those characteristics stated above (deep / crystal clear / 3d finish). I’ve tried multiple resins but unfortunately - not many people here in this town are knowledgable w/ this fabric.
:?: What resin is best used to obtain such a finish?
:?: Process correct?
:arrow: By following your basic tutorial - cutting the fabric larger than the item to be covered - saturate both fabric and surface part (waiting x minutes for tackiness of surface)… allow fabric to drap evenly / naturally - assist with any uneveness / bubbles - allow to cure - cut edges w/ cutting instrument and then sand to edges w/ appropriate grits. Apply further coating if needed in between sets / clear coat w/ UV protectant for exterior use.
I suppose I’ll leave this reply as it is before picking your brain / talent / skills many more rounds w/ my questions that I have from covering a dash / vacuum bagging / molds / etc :shock:
Thank you so very much for your time
- Jason
