Hi folks,
I am constructing a three wheel buggy that requires 25mm diameter rear fibreglass suspension axles. Cant buy any here in the Philippines so I will try to make them myself. The method I will use will be to add release agent to the inside of a length of 25mm.ID ( 1" to those countries still catching up
) rigid PVC electrical conduit then pack it loosely or tightly? with glass roving then using a vacuum pump, suck the resin up through the PVC then wait for it to cure.
Iām confident this will work but Iām not sure about the glass/ resin ratio, will more glass make the rod stronger and less brittle?
The glass roving will be from dismantled heavyweight woven roving as I couldnāt find a roll of the rope type.
Thanks, Bob.
