I need to make some medium sized (2m*2m) cored panels.
I’ve already got my 10mm rohacell foam core, but It’s not the infusion type so has no flow channels.
I ran a small test panel and cut grooves in x and y direction on the downward facing side using a pizza cutting wheel, and drilled 2mm holes where the grooves intersect.
It didn’t infuse the underside very well, there was a huge dry patch near the vacuum side.
What information can anybody offer? Thanks.
