Hi All,
In the process of building a small autoclave using a Binks 15 gallon pressure pot. I have a few questions regarding plumbing I hope someone can help me with.
(a) Vacuum line - I have 3/8 NPT access point in the front of the pot that I want to control the vacuum with i.e., pull vacuum and also release vacuum while under pressure. The question is what type of fitting do I need here ? as the main concern I have is if I have a leak, having 90 psi go backwards through these fittings.
(b) The next plumbing issue is going to be running the heater and themocouple into the pressure vessel; has anyone tried this type of thing ?
Thanks in Advance,
.adrian
