My set up is a Hyvac-7 pump and an HF pressure pot as resin trap, and an Air Logic vac switch. The pump kept cycling on every two minutes, so after buying a leak detector and not finding any leaks, I completely disassembled every single fitting, nut, bolt, etc. and found oil in the bottom of my pressure pot.
So I fill the pump with new oil and it holds vacuum for hours. The next day I check the oil level and it’s empty, nothing on the floor, all in the pot!
Long story short, the vacuum built up in the pot is sucking the oil out of the vacuum pump! I bought a PCV from the local store and it’s lessened the effect, but I can still see oil half way up the tube leading to the pot. When the pump cycles on, it strains and then sucks all the oil back in. I tried making a tall round about vertical path for the tube but it’s still doing it, just not reaching the pot anymore.
Anyone ever experience this? The Hyvac site doesn’t say anything about a one way valve. I could make a separate catch tank for the oil, but once the pump loses oil, it becomes a vacuum leak. And I’d have to keep refilling it back in to the pump. I’d rather not engineer a catch tank, recirculator, swirl pot thingy for all this.
