I have some epoxy resin which viscosity isn’t suitable for infusion.
So I would like to add more additive in epoxy resin in order to get better viscosity .
What additive should I use ? … only thinner ?
I believe, you can not do that with thinner … you need proper infusión resin …
If you do not have an exact idea of what you are doing, diluting epoxy is not recommended. Especially not when doing it with light carbohydrons (acetone, toluene) and infusion.
Epoxy is usually made thinner by either destilling or dilluting with reactive diluents (mono or difunctional)
