That isn’t necessarily true. It also depends on the contraints of the project. If the constraint is fiber volume then a hand layup for the same volume of fiber can out perform a compacted piece of equal fiber volume. This is because the hand layup ends up thicker though heavier. The extra thickness increases the stiffness which can reduce the propensity of the structure to buckle under compression.
If the constraint is maximum strength for the least amount of weight then a properly compacted layup will perform better though an increase in fiber volume is required.
I’ve also tested infused and vacuum bagged laminates that were so porous that they performed rather poorly. Often vacuum bagged hand layups get too much resin leeched out of the layup due to the neglect of not using the correct perf-ply…or no perf-ply at all.
I use a lot of pressure assisted methods but they don’t determine the quality. A quality product is one that meets or exceeds the structural requirements and makes the customer happy. Some requirements require the use of compaction to increase the fiber volume fraction to meet a weight objective. Some requirements do not.
I think none compacted carbons look much better than squished ones. If the customer is wanting cosmetic bling, and doesn’t want the squished appearance, then the shop needs to alter their methods to meed the expectations.
