I am having aluminum molds machined and plan to do my part with prepreg and bladders. Before I spend the money to have molds machined I want to make sure I have the details of the mold design worked out.
My part looks like this (inlet/outlet are 65mm):
For the bladders I am planning to lay sheet wax into both halves (laminate thickness), then use smooth on’s brush on vacuum bagging silicone.
One of the questions I have, is there a preferred method for attaching air fittings to the bladder? It looks like this will have an impact on mold design so I need to figure it out before I have anything machined. I am looking for a reliable connection that won’t put unnecessary wear and tear on the bladder and that I won’t need to spend a lot of time futzing with on each part.
Bladder forms gasket:
Big rubber plug:
Fitting wrapped with rubber band:
For heating elements I am planning to use cartridge heaters with a loose press fit into the mold. I expect the the mold will be close to 20lb. 6 heaters press fit into each mold half like this:
If I use 100w heaters I will have a total of 1200w to heat 20lb of aluminum to a target cure temp of 250F. Does this seem reasonable?
Lastly, the thermocouple. I am planning to use a short screw in thermocouple and design the hole so that when the thermocouple is tight, the end is making contact with the mold surface. Is there a better method?
