Hi folks,
I was just wondering about the various pros & cons when designing a motorcycle part like this: http://www.oppracing.com/product_display/3079-macmoto-series-airduct-sbk-right-gsxr1000-20052006/
It’s basically a few pieces forming an entire front fairing with ram air ducts.
They have used Kevlar, but I’m wondering if it’s really worth it, or whether you could achieve 90% of the result at 10% of the cost using something like Innegra?
Probably the main consideration is to ensure that the part won’t break up in a crash, but a secondary benefit could be that the part takes minimal (or zero) damage in a crash.
But a part is only as strong & durable as the weakest material, in this case that would be the plain carbon fibre?
Say for instance that a part was crushed, it would surely deform and crack? Obviously the same would happen if Innegra was used, but to what extent would the Kevlar part have an advantage, if any?
Also how much of a factor would delamination be? Comparing the effectiveness of a carbon/Kevlar hybrid and a part using a sandwich layer of Innegra? How close would the performance be if you then compared a Kevlar hybrid with an Innegra hybrid?
If you were building a part like that, would you go to the expense of using Kevlar?
Thanks for any insights, looking forward to your responses.
