Hi. I’m looking for references info material on how to design composite structure shapes to be strong in certain directions, to resist buckling etc achieve our design goals with less material.
How to form and curve our composites, molding on beams and other types of structural support to achieve the desired result.
For example I-beams, girders, structural ties, rods, compression members, trusses, cantilevers, thin shell structures and so forth.
What is the area of engineering that deals with the field?
Ideally I want a book on references of common structural forms. I’d like to see a diagram with different variations of the same principle. I’d also like to see a short theoretical principle of how the forces are handled and some brief theory to outline in which direction certain pieces of the structure needs tensile strength/compression/rigidity/elasticity and so forth and what the major failure points are.
