@canyon: a full cure is not reached in that case. If the epoxy improves after a postcure, that is because it cures further.
Warm-curing epoxy (what we use mostly) will cure at room temperature, but will only reach full cure at elevated temperatures. In general they reach 80-90% of the potential cross linking, very much depending on the type of epoxy.
A free-standing postcure is possible, but to avoid any distortion, temperature control is absolutely neccesary. Depending on the size of object, do not elevate the temperature more than 5 to 10 degrees C per hour. The Tg of the resin will in general be about 10-15 degrees C over the highest temperature achieved (until ultimate Tg is reached).
This means during a free standing postcure, you like to push the Tg forward, not run over it.
