i just got a 3 gallon aluminum degassing chamber from BestValueVacs so i could start degassing my epoxies.
i went to do my first degassing session, mixed up about 6 oz of some pretty thick epoxy, placed it into the chamber, and turned on the vacuum pump.
i’m using a Robinair 15600 6 CFM pump, so its decent and started pulling pretty quickly, it reached full vacuum in about 15 seconds. the bubbles started forming and raising just as expected within 45 seconds. but this is where the trouble starts, as it just hangs there:
no self collapse, even after 10 minutes.
so i shut it off and pulled out the epoxy and what i’m left with is an epoxy that has more bubbles in it now than when it went in:
even after letting this air off for 5-10 minutes, many bubbles still remain:
so i assumed perhaps the viscosity of the epoxy was too high, and it was just too thick to be properly gassed off quickly. so i tried again with a much thinner Pro Set laminating epoxy, and had the same results, with no self collapse:
what am i doing wrong? is the pump not strong enough? chamber too large or too small? something else?
