I’m working on the design aspects of creating a hollow fiberglass “D-shaped” tube. Internal dimensions would be maybe 30mm Height x 40mm Wide at base. This piece would then be secondarily bonded to another structure (along the flat side of the “D”) and then secured with additional layers of fabric vacuum bagged into position.
(I want a better bond than is available using a round tube with fillets)
For the male mold, I’m considering some kind of foam that can be dissolved via solvent after curing.
Will that work, and if so what kind of foam do you recommend?
Super nice equipment there! I’m hoping to start some small things by this fall. But until then I just keep hammering away at research, building the thing over and over in my mind and scouring these boards.
