Cylinder
Hi All,
How to manufacture a closed cylinder filled with foam using GFRP.
With Regards,
Gurudev
It depends on the application and required characteristics.
Easiest way is probably to wrap the glass around the foam in a wet layup.
Thanks for your reply, we have tried this , layer are getting slipped when we wrap the glass around the foam, kindly do suggest any other alternative method
Hi
Can you post more details please IE size of the cylinder plus the reinforcement specification and some images.
Regards Chris
best might be a large braided tube that you can pull over the cylinder this way it can’t really shift much.
I suggest a braid as well. The top and bottom can be normal layers of fabric, alternated with the braid. I would suggest vac bagging it though. Not sure how the braid will stay tight otherwise.
Dear Chris,
Please find the dimensional details of the cylinder as requested
its 100 mm out side dia
and inside is 98 mm dia
height is 100mm
Kindly do guide us how to manufacture the same.
With Regards,
Gurudev, PMP
Hi chris,
Sorry i submitted the request under Quote, please ignore the same
height is 100mm
With Regards,
Gurudev, PMP
Hi chris,
Please ignore my previous mail and kindly consider this
height is 100mm
Inside is filled with PU Foam.
With Regards,
Gurudev, PMP
