lately i’ve been cutting and sanding all my parts and molds on my balcony outdoors. It makes a lot of noise and a lot of dust that is harmful to breath for everyone around. I wear a good dust mask but that’s just not sufficient for dust control.
So here’s the inspired plan… build a glass bead cabinet, but out of 3/4" thick mdf. It will have thick rubber gloves just like a glass beed cabinet and a nice light inside, along with a thick tempered glass window to see through. I’ll use foam rubber gasket to seal the lid closed along with a latch. I think I can build it for under $100.
The benefits are: much much much less cutting noise; no dust outside the cabinet while cutting; a shop vac and hose can be plumbed into the cabinet bottom or side or a dust collection unit. To eliminate the noise of a dust collector or shop vac i may use a waterfall filter set up… fan blows the airborne particles into a filter that has water running down thru the filter, an inlet filter on the opposite side of the cabinet made of paint booth filter or a heppa air filter. water collects in a tub underneath the cabinet and gets filtered then pumped back to the top. You never need to dump the water as it will evaporate and you just add more as needed.
Everyone is happy, me and my neighbors… it’s a win win thing.
I’m gonna build it 29" wide x 34" deep x 32" high. It will also have legs to support it to the correct work height.
 2.i ve discovered that using a dremel to cut fiberglass sometimes BURNS it due to high temps. 3.its easier to handle, while an awkward movement with the power tool can ruin your creation. 4.the motion of the blade makes it easier to handle, and cut shapes. 5. you dont risk a broken drill bit taking an eye out.
  2.i ve discovered that using a dremel to cut fiberglass sometimes BURNS it due to high temps. 3.its easier to handle, while an awkward movement with the power tool can ruin your creation. 4.the motion of the blade makes it easier to handle, and cut shapes. 5. you dont risk a broken drill bit taking an eye out. used for spraying tooling gelcoat for molds and white gelcoat for fiberglass parts
