I am planning to cut some carbon fabric patterns on my cnc mill using a tangential knife setup. I have been trying to figure out a way to cut the dry fabric without the edges fraying. I know that most cnc patterns and kitting is done with prepreg.
I think that the trick to doing this would be to apply a thin coat of adhesive or silicone rubber or something else and let dry, then cut?
Does anybody have any suggestions for cutting the dry carbon without the fraying around the edges? Masking tape won’t work for this application.
I will be using the standard 3k weave carbon and laying up in a closed mold and heat cure.
Thanks!
Matt
