Hello,
I am using a 10mm carbon tube as a shaft inside a bearing. I have to sand down the OD of the shaft about 0.12mm to fit the bearing and also cut lots of little tubes to length. Currently I am cutting the tube with a fine tooth hacksaw and reducing the OD by sanding with 320 grit sandpaper. This seems to work fine, but I get a few small splinters where I pass through the far side of the tube. I think the tube is extruded because the splinters/fibres run parallel to the tube axis.
If I have to make a few more of these RC aircraft parts I’m thinking about getting a mini lathe to make the cutting easier/neater. Would a hacksaw still be the best way or would some sort of cutting bit be better? I’m thinking that hacksaw blade + lathe may be better because the cutting pressure will always be from the outside inwards. I’d have to be careful not to clamp the tube too tightly because the wall thickness is only 1mm. I know carbon dust is bad for electrical equipment.
Thanks.
Thanks.
