Hey guys, As just a starter I used my old fridge compressor rigged into a vacuum pump and it worked quite well for what I needed.
I recently scored two of these pumps for a good deal. So I started to set one up.
I plan on starting to infuse my parts as it seems like the way to go! I have only really done bagged over lays and wet layups as of now. Anyway here is the start.
The t fitting right after the vacuum gauge is going to get plumbed with another valve to a degassing pot. I set up another t for dual vacuum lines on larger parts…Not sure if I will use it often but figured i have the fitting might as well.
All closed off the compressor pulls 27.5 in, this should be alright right?
Let me know what you think and if I should change anything.
Nolan
