I thought this would be a perfect infusion…ohh I was soo wrong…
test piece:
two layers of 9oz twill glass
initial layer of 3mm soric
second layer of soric (center section for rigidity)
the vacuum and infusion mesh are located directly on top of the glass and soric, in hopes there would be no transfer issues.
Vacuum was good across the entire setup, but it appeared like I couldn’t get resin flow into the soric, it basically stalled out.
what would cause the resin not to flow into the soric channels? if that was the issue.
This is a custom Targa top I’m attempting to create.
https://www.dropbox.com/s/8s4vt5zml7biimq/2014-03-19%2019.23.54.jpg
https://www.dropbox.com/s/m4nm9gbe4tj3i3r/2014-03-19%2019.24.04.jpg
