Hey,
At the moment there is an option I have to produce about 150 of the same parts (simple panels, rounded surface, sharp edges, 1 inch deep, 2*2 foot)
Does anyone know of study’s/reports on wich method becomes cost effective on what point?
Both vacuum infusion and RTM-light we can do relatively easy in-house. We have most of the equipment an knowledge available, so setting those two up is no big investment.
The big advantage of RTM-light seems the setup time. No hassle with feed or vacuum lines, and the process is simpler (wich means i can get some people from other departments and interns to run a production quite easily
And what about re-usable vacuum bags in vacuum infusion. that’s quite a time saver too, anyone experience with that? I got an old quote for latex, wich would survive 50-100 cycles. I think most of those are just too stretchy, and costly in comparison to RTM-light.
(I’ve never had productions this big, quite a learning school…)
(and Herman, I know you’re reading, check your mail
I’ll give you a ring when we actually going to need supply’s for infusion/rtml. Could you mail some info on those mould fasteners, I hate using nuts an bolt on splitmoulds…)
