I need a generic flat panel.
I can’t grab scrap honeycomb core, so I wanna get some foamcore from fi****st.com or elsewhere.
It has to be about 1x2 foot, and pretty strong. (luggage rack for motorcycle, to replace the 10lbs metal one)
Should I just add a layer or 2 of prepreg, and forget bout foamcore? Is 1/8" foamcore reaaaaalllly that strong to dignify the use of it?
You might try checking out Plascore www.plascore.com and they will sale small orders too.
Just tell them you read it here, please!
Or you might want to try perf-paper core mat too.
The core will give you an “open” space for light weight strength, sort of like a box or tube. the “open” space can help with torsional rigidity if the shapes are designed properly and weaves laid properly. youcould also use strips of core to make a corrogated structure.
