I did my first vacuum resin infusion part using a core. This is not my first resin infusion, just my first with core. I won’t say I’m a total pro at resin infusion, but without core I have made some very good parts.
Here are the particulars.
5.7 oz plain weave carbon
Endurance resin
1/8" thick Divinymat structural flow media. The grooved and scored kind.
mixture of plain peel ply and teflon peel ply.
The layup was 2c1 with the 1 being on the inside of the mold. The part was laid up and max vacuum was pulled for several hours.
The vacuum was reduced to 18" and infused. After the infusion was complete a second bag was placed on the part. 18" was maintained in the first bag and max vacuum was applied to the second bag. The part was tented and cured at approximately 100 degrees F. Vacuum was maintained until well past the green stage and probably until a full cure, 5 plus hours. Due to it being a Friday. The part stayed in the mold for over two days.
As you can see in the pictures the carbon “puckered” around the edges of the core. Even though the core was only 1/8" thick, I beveled the edges with a sanding block . What caused this and how can I prevent it?
