Have already built one bamboo mountain bike and wrapped the joints with carbon tow to form the lugs. I used hi shrink tape for compression on the lugs. Worked okay but I’m pretty sure there’s a high resin to fiber ratio. After a year of riding none of the joints have failed so seems to be strong enough. For the next frame I want to try vacuum bagging but have a couple concerns.
There are 5 main joints on a traditional frame so that means I will be bagging the frame five times. So my question is when bagging, does the pump have to run constantly until the cf/epoxy cures on each joint before I can start the next joint? My first frame only took me about 6 hours from start to finish to wrap all the joints, this could take days if so. I’m only asking this because I don’t know, but when bagging, once you get enough air out, can you clamp off and cut the hose and move on to wrap the next joint and bag it? Does that even make sense?
Do you guys have any recommendations for a cheap small vacuum pump that works fairly well? The area of coverage for each joing will be less than 1 square foot.
Thanks.
