compress molding
I’m making a part that is 3 layers of 3k twill carbon fiber. I need to compress mold it and have no air bubbles in the surface of the part for asthetic reasons. The part is 4" round with a 1/4" length 90 degree lip. The corner is radius’d about 1/8". So far the corner has no air bubbles or voides… just the main surface has tiny air bubbles.
I can use polyester, vinyl ester, or epoxy so long as i get a clear finish for the visual effect.
Any suggestions?
What is the press molds made from?
I would love to see a few pics of the mold pieces and finished product, perfect or imperfect. What resin and lay-up steps are you currently using?
Also, what kind of weight is your finished piece?
Im asking all this because I wish to make an RC model Deck Hatch very close to this size out of CF. It must, must, be very light and of a sufficient strength.
Your current process and also some solutions for your imperfections would be very welcomed info.
Is it pre-preg or wet layed?
