Hi folks,
Just hoping to gain some insight from those with experience in selecting the right material for a job. We all know that as great as composites are, sometimes they’re just not the right choice or a cost-effective one.
My situation is that I’m going to be fitting out my work/play van with overhead cabinets, shelving/lockers and a workbench with drawers and some other stuff like a custom shaped nook to stash away a couple of stools.
The big question now is what material would be the best choice? Immediately I thought of aluminium to keep the weight low and reduce any future rust problems. I actually went and bought about $500 worth of ally a few months ago when I was first thinking about this - but that was basically only enough for a lightweight workbench and the plan has changed a lot since then.
Given the size of the project it’s only going to be possible if I do most of the work myself. Using aluminium means I would need to get a suitable MIG/TIG and learn how to weld.
Then I just happened to be reading something today that mentioned alloy and steel being pound for pound about the same stiffness. So I wondered about spending a bit more on steel and using a higher grade with thinner walled tubing? Maybe the learning curve on the welding wouldn’t be so much, and I already have a MIG I could use.
I had been thinking about the option of composites mainly for the overhead lockers/cabinets that I want to make with a rounded shape like the airline lockers. But then tonight I got to thinking about doing the whole lot, shelving and workbench in composites. I know it’s a lot more work to make a single piece from composites, but if I had to choose one material (ally, steel or composite) that I really want to work with and learn more about, it’s composites. Eventually I want to be able to make some money on composite projects and go into business for myself, so I figure that I should be taking every opportunity that I can get to work with it. If I went through the process and had the molds all done I’d be looking to sell a couple of parts as well.
But I have also learnt the need to be realistic, on occasion I have bitten off way more than I can chew. But at least that always ends up being one hell of a learning experience! I am fully prepared to invest the money and time to learn how to weld if that turns out to be the best option, and the same goes for composites. If that is a good option, or even just “viable” then I will commit to it and put in the time to get it done.
So - what do you guys think? I’m not even sure on what kind of composite construction I would use, for instance whether I would make the bench out of one large mold or just cut down sandwich panels to size and affix them using ally angle and something like 3M VHB tape (or another adhesive)?
Thanks for reading, I would really appreciate any input.
Cheers,
Conrad
Depending on what you want to physiclly do, composites would be lighter weight. You can just mold flat panels and rivet/bolt/glue them together to make a structure, like a table, or storage rack. A simple CF plate that has some metal shelf brackets…it would be light weight. However, it would be more expensive than steel or aluminum.
