Im making a composite plate from Woven E-Glass fiber(600 gsm) and Ployester resin using a Volume Fraction of 50%. The total weight of the plate is not to exceed 15kg and area of the plate is 4.55m2.The thickness of the plate should be less than 3mm. Vaccum bagging is the preferred technique. 8 plies are to be made with 0/90 stacking sequence.
kindly instruct me how to manufacture the plate with the given specification. What quantity of fiber and resin should i add and how to USE GSM term ?
