Hi All
I need to join an Aluminium part with a hollow carbon fiber square rod of about 25mm diameter.
It is for arm of a Drone/multirotor/Quadcopter.
Most designs in the hobby industry use clamp type designs.
Some professional companies seem to use rivets (or other types of fasteners.
My concerns:
Clamps may work for round hollow rods but for square/rectangular ones, there is risk of crushing by oversampling
Not sure about rivets , but screws/bolts passing through carbon sheets/rods tend to eat away carbon fiber (the holes in carbon fiber enlarges)
Solution:
Bonding and slight tapering of mating surfaces
If I keep the metal part slight tapered and cure the CF rods directly over the part , such that the taper mechanically locks them against any pulling force, will that work?
About 1-2 degree over a 30mm length of mating area will be enough?
Square rods will also prevent any twisting/slipping
Also I read online that Carbon fiber corrodes aluminium by Galvanic corrosion
How much should I be worried for it? What if Aluminium is already anodized before coming in direct contact with carbon fibers?
