Hi Guys
I have just started a new hobby of rc planes,helis and copters. And now plan to build some of my own.
Here are a couple of doubts I have:
- Prepregs already impregnated with resin right? Vacuum bagging and curing them won’t require any more resin to be applied?
2)We can cut into prepregs(before curing), can’t we? Say make slots in them, shape them to our needs, make them into circular plates etc. Can we drill holes them? Has anyone tried making small holes in uncured prepregs, something that can generally be achieved by drilling only
3)For general (non-prepreg) vacuum bagging how does one estimate laminate thickness and and volume fraction of fibres( I researched a lot online. Have not got any real answer. Best answer was from Fibreglast. For a particular farbric,resin and manufacturing/curing combination, there are estimates for laminate thickness and Vf. Is that how it is supposed to be done? by experience?)
Making round hollow tubes. The best (and cheap) DIY method? Just vacuum bagging will still give a seam line, the line where the vacuum bag rolls over and meets the other end. Would adding a flexible half cut pipe on that end of the tube improve finish?(between the vacuum bag and the breather cloth to not be indirect contact with the actual fabric)
What vacuum pump should I go for? How do we size (cfm or volume flow rate)? I understand better the relative pressure drop with respect to atmospheric pressure, more the pressure acting on the part. Higher the cfm, more quickly vacuum can be achieved. However, a local manufacturer told me that a smaller pump(low cfm) with high vacuum pressure rating will achieve lesser vacuum for a large part. Any scientific reasoning behind that (unless the larger the part the more chances there are of leakages?).
Dry vs wet vacuum pumps
7)Safety, what masks to wear? How to dispose off waster epoxies and fibres.
Apologies if any or all of these are covered in other threads.
Thanks in advance:)
I was looking for CF tubes in local hobby stores. Everything is out of stock
