I’m planning to infuse a small three layer CF laminate (one layer of 10 oz uni followed by two layers of 7 oz 2x2 twill). The laminate is flat and approx 15 inches in diameter with a 1/2 inch lip around the perimter. After reading some posts on here I think I’m going to try Adtech’s 820 infusion epoxy (unless you guys recommend another infusion epoxy that will cure at RT) with Compoflex RF150. My question is this: Is it acceptable to use a layer of peel ply (red stripe for example) between the laminate and the Compoflex? The only reason I want to use the extra peel ply is to get a smoother finish on the laminate AND because I dont think the Compoflex will conform to the 1/2" lip around the perimeter of my laminate (the lip is angled outward approx 45 degrees). I should note that I’ve only used the Compoflex SB RF 150 before and it left a VERY rough surface (which by the way MUST be sanded for a good secondary bond… I found that out the hard way!). My plan is to (a.) lay the laminates, then the red stripe peel ply over the entire laminate, then the compflex, then bag -OR- (b.) lay the laminates, then red stripe peel ply JUST over the 1/2" lip + 1/2" or so each side of the lip, then the compoflex over everything BUT the 1/2" lip, then bag.
Any advice appreciated!
BTW: I have some VE infusion resin that I could use but I’ve heard VE doesnt wet out CF very well so I’m spooked to use VE on this part.
