Hye everyone ! i’m new here and need advise.
I planning to combine cure in the autoclave, but i’m not sure if it possible and appreciate if someone can provide me the answer for my question below.
Is it possible we cure composite part with different tool material. For example: combine cure with tool fabricate from invar and steel. Is it possible, since both material has different thermal expansion.
if it possible, how we determine the heat up rate for the cure cycle. since i need to meet the cure cycle requirement i.e heat up rate if i combine the cure with both tool inside the autoclave.
